tmJak Posted February 2, 2009 Posted February 2, 2009 One of the belts at the front of my engine is making a high pitched squeeling noise, and I seem to have a leak of power steering fluid. The tank is now below minimum level. I've got my car booked into TDi North on Wednesday, which is around 20 miles from my house. Does anyone know (probably should just PM gixxer) if I will cause any damage driving 20 miles with low level of fluid? Â Here's to hoping its not the pump that's gone. . . Quote
fatalus Posted February 2, 2009 Posted February 2, 2009 You can always go and buy some power steering fluid...it is fairly generic Quote
tmJak Posted February 2, 2009 Author Posted February 2, 2009 I suppose. . .that may be the sensible thing to do. Does it not need to be the specified Nissan type? If the pumps not broken I don't want to do anything to damage it. They cost about £500 Quote
fatalus Posted February 2, 2009 Posted February 2, 2009 Actually, according to the manual any Dexron III fluid will do. Quote
tmJak Posted February 2, 2009 Author Posted February 2, 2009 cheers, i'll drag myself to a garage tmoz Quote
cgomez1978 Posted February 2, 2009 Posted February 2, 2009 you can buy some power steering fluid which seals leaks i had to buy some on my last car i think it was called scotts, they are normally on ebay as well Quote
M13KYF Posted February 3, 2009 Posted February 3, 2009 you can buy some power steering fluid which seals leaks i had to buy some on my last car i think it was called scotts, they are normally on ebay as well  don't like the sounds of that, Like rad weld, only use in a dia emergency cos it bungs everything up Quote
R35LEE Posted February 3, 2009 Posted February 3, 2009 All of those 'quick sealing' additives are awful!! Usually cause more damage in the long run. Quote
ZMANALEX Posted February 3, 2009 Posted February 3, 2009 Any automatic transmision fluid or pas fluid will do the job and not cause any harm. Â The stuff that Nissan supply is generic and carries the following description and part number: Â AT-Matic D Fluid Incl. N-CVT Â KE908-99931 Quote
Stew Posted February 4, 2009 Posted February 4, 2009 My level dropped and was a little noisy. I topped it up and it was fine. No leak, not sure what happened to the fluid though...... Â Hope it's not an expensive outing Chris! Quote
tmJak Posted February 5, 2009 Author Posted February 5, 2009 My level dropped and was a little noisy. I topped it up and it was fine. No leak, not sure what happened to the fluid though...... Hope it's not an expensive outing Chris!  The level keeps dropping, and I have a pool of liquid at the bottom of the engine bay. Hoping it's a cheap one as my Zed's been very expensive this Christmas!  Thanks for the replies everyone and I'll post up when I know what the problem is Quote
tmJak Posted February 5, 2009 Author Posted February 5, 2009 It looks on first inspection that a jubilee clip has degraded some and is causing the power steering fluid to leak. I'm gonna get this sorted, and hopefully the pump is working fine, although it is making a bit of a strange noise. . . Will know for sure in a few weeks. Â Only problem is that to access the jubilee clip the front bumper has to come off! Means a 2 minute job will actually take a couple of hours. Quote
Stew Posted February 6, 2009 Posted February 6, 2009 The pump will probably stop making a noise when it's getting a constant steady feed of fluid. Quote
tmJak Posted February 6, 2009 Author Posted February 6, 2009 Fingers crossed Stew. Â Does anyone know if the samco hoses include the power steering hoses? Quote
ZMANALEX Posted February 6, 2009 Posted February 6, 2009 Fingers crossed Stew. Does anyone know if the samco hoses include the power steering hoses?  Unfortunately they do not.  Pirtek will manufacture pressure hoses for you if required. Quote
tmJak Posted February 6, 2009 Author Posted February 6, 2009 Fingers crossed Stew. Does anyone know if the samco hoses include the power steering hoses?  Unfortunately they do not.  Pirtek will manufacture pressure hoses for you if required.  No it just seems a shame to have mechanics working on my car and not modding it at the same time.  Cheers again Alex Quote
ZMANALEX Posted February 6, 2009 Posted February 6, 2009 Fingers crossed Stew. Does anyone know if the samco hoses include the power steering hoses?  Unfortunately they do not.  Pirtek will manufacture pressure hoses for you if required.  No it just seems a shame to have mechanics working on my car and not modding it at the same time.  Cheers again Alex   Ah! I get your drift now.  Okay.............  Pirtek will manufacture colour coded pressure hoses for you if required.  But remember nobody will know that they are there, except you Quote
