Xenon Bulbs
ireynolds
Search for "Hi Beam" and all the info is in there.
I was looking at your Bulb order the other day, seemed to be more bulbs on order than places to put them !! ;)
Which was which ? and u ever come across a decent LED Brake bulb?
Plain Indicators? PH582SV WY21W Wedge Philips SilverVision
(pair) £15.45 1 £15.45
MAINBeam? H7PXP H7 Philips X-treme Power +80% bulbs (pair) £32.99 1 £32.99
? 501LED201 501 LED Quad Bulbs Options:
Colours: White £8.50 1 £8.50
? LED5011WP 501 LED Extreme Power 1W OptionsColour:
White £12.50 1 £12.50
And from priracing.com
Sidelight H322 PIAA LED sidelight bulb 4 element
(pair) 1 £21.00 £21.00
Ah well spotted!!
I bought 2 lots of the 501 to see which ones would be best up front and then used the ones that wernt as good in the rear numberplate and then used one more in the light in the trunk....
On the rears, am not sure unfortunatly, I got the updated Nissan LED's off alex on here, but they are not here at my flat or I would have had a look for you....
I dont think there are any other "bayonet" type fittings on the car so am going for a plug in type but it would be a massive guess!!
M
Hi all,
My drivers side Xenon bulb has gone (headlight) on my GT UK 350z.
Can anyone tell me what bulb to look for to replace this, and what sort of cost i am looking at?
Is it a hard swap?
I believe the HID bulb you require is a D2R. Think they are £100ea from Nissan, but you can get them for around £30-£40 online, or from independent auto-parts stores.
To swap is a pain - you have to either remove your front wheel and inner arch trim, or remove the front bumper and detach the headlight.
