BOSE help
350zPaul
Hi there guys.
Problem with the BOSE head unit. i press the cd button and nothing happens for a few seconds and then a message saying push (or press) eject appears and doing this does nothing. Cd's dont come out and they dont play, Radio works fine though. It has happened before and it corrected itsself last time. :rant: its murder driving a car with no music
Can anyone help?
Cheers
Paul
When you press eject you then have to press the CD number you want ejected? ;)
Not structly true.
Thats only if you want to eject a CD thats in a diff position to the one you are currently listening too.
Try pushing an holding the Eject button (this will normally eject all 6 CD;s in sequence).
Failing that, use impact engineering and hit the flaming thing! :teeth::lol:
Not structly true.
If there is a number flashing it can indicate a faulty disc though.... ;):)
