hagar Posted April 25, 2006 Posted April 25, 2006 can anyone recommend or tell me of a good replacement set of front pads? I know I can get red/green/yellow stuff but I want something I could go down to halfords (I know!) and buy over the counter so I can do the brakes tonight. If Mintex etc do them, does anyone have the codes? Or ferodo etc? also any recommendations for DOT 5? Halfrauds have some in at £9 per litre which is rather eye catching cheers Quote
Kev946 Posted April 25, 2006 Posted April 25, 2006 Not sure about Halfords, but I would go Ferrodo DS2500's. I run the DS3000's in the Cossie and they are awsome. These eat disks though so will be going the DS2500's next. Most of the Cossie boys use these and they are supposed to be superior to EBC. As for fluid I use Motul DOT 4 stuff. Don't forget that DOT 5 does not absorb water. This means any water can cause vapour lock with temperature, i.e. on the track. I therefore use a high quality DOT 4 by looking for a very high boiling point. I bought all my stuff from Demon Tweeks, (dear but you can get next day). Cheers Quote
Guest prescience Posted April 25, 2006 Posted April 25, 2006 Kev, I did this FAQ a while ago; can you check it out and let me know any further info/corrections since you've clearly done some research http://www.350z-uk.com/forum/viewtopic.php?t=401 Quote
Kev946 Posted April 25, 2006 Posted April 25, 2006 Dorian, Will check this out later when I have more time. First reaction though is DS3000's are very very aggressive. They are really for track cars. I was told you can eat a set of disks in 2 track days. I've done about 3 in mine and they are still OK though. I was told DS2500's were the best bet. I tried DS2000's once, (I ordered DS2500's and got these without knowing). I destroyed them on the first track day. Cheers K Quote
Guest prescience Posted April 25, 2006 Posted April 25, 2006 Ta Kev Slow time is fine but input is needed to get it right; which it may not be as you note at present. Let me know or PM me and I can post your input up to replace or augment mine. Quote
hagar Posted April 25, 2006 Author Posted April 25, 2006 thanks for this fellas Never thought about the DOT5 issue, I'll go for DOT4 and some upgraded front pads - I saw a link the other day to a guide on removing pads so I'll go hunt for it Cheers again Quote
Kev946 Posted April 25, 2006 Posted April 25, 2006 On fluid, pick one with a very high boiling point. DOT 4 is already a high spec but some are have a relatively low bioling point. Quote
hagar Posted April 25, 2006 Author Posted April 25, 2006 what should I consider a good boil point? 600/700/800 and is that C or F Quote
Kev946 Posted April 25, 2006 Posted April 25, 2006 I can't remember TBH. I use Motul stuff from Demon Tweeks. It's a high quality and reasonably priced. I'd have to check on the bottle which is at home. 300 deg C rings a bell. Why not check on the Demon Tweek website. Do a few comparison. The AP fluid is top notch stuff but costs a bomb. They have a website as well. I think it's www.apracing.co.uk Quote
Removed Posted April 25, 2006 Posted April 25, 2006 it all depends on what you do with the Z really. Pads: prject MU are really good too, if you listen to my italian friends over at their Z forum, quite a few track nuts over there Quote
hagar Posted April 25, 2006 Author Posted April 25, 2006 well I might just get the standard nissan ones fitted :| Dot 4 wet boiling point is 311 which is considerably more than DOT3... Quote
