Hi guys,
I need to remove the speedo clocks in order to remove a bulb so that the airbag light wont stay on ( as air bag was removed and this will not reset).
Just wondering if anyone could direct me on how to do this. Thanks
Hi guys,
PM lomoto - he's done it. :thumbs:
Undo 4 screws holding cowl around steering column, prise apart cowl ( a bit stiff thiese !! ), undo 4 10mm headed bolts that hold speedo assy on to steering column, pull out electrical block connector at the back of speedo and thats it ..10 min job :thumbs:
We need a little write up with pics in the Guides section. Anyone want to oblige? :)
Ill give a go considering my vast knowledge in car mechanics...
one of these ...
or one of these should do the trick..
if any one needs help fitting a turbo kit dont be afraid to drop me a pm lol
Haha....ill...pass :)
Ok im a try this tomorrow.... take pics as i do it so hopefully can be sticky in technical section.
Thanks
Good man! :thumbs:
one of these (otherwise known as an Irish screwdriver)...
lol
