Z1 Motorsport plenum spacer install help
Hi all,
Finally took the plunge and bought one of these... the instructions say Tighten all bolts to 44-61 inch-lbs.
Obvioulsy ill need to look online and convert this to ft-lb or nM as none of my tools are inch pounds.  However this is quite big margin, what would be recommended?
Edited by iNezzy
  • iNezzy changed the title to Z1 Motorsport plenum spacer install help
Hi buddy,
I would as you say check online 1st. They are usually torqued down in stages. They should also follow a pattern which should be with the instructions? Sorry I can't be of more help but I am sure someone with more knowledge will be along shortly to advise you better...
Best to use an inch-lbs torque wrench.
For reference 60 inch lbs = 5ft lbs or 6.7791 nm.
However, as Andy has said, the bolts have to be tightened down following a specific sequence.
If you require this sequence, then let me know.
Here you go.
Aim middle for diddle with any torque range, so 52 inch lbs.
Inch lbs is small by the way, my 1/4 drive drive torque wrench is marked in inch lbs.
Seems to have gone well, jwt popcharber and z1 plenum spacer both fitted and good to go.
Car feels slightly juddery when pulling of but once driving seems to settle, its not in for a tune with dynatune until next month. Would it benefit for the peddle dance maybe?
Other than these mods and the full exhaust anything else recommended before tuning?
@ZMANALEX @Keith D
Edited by iNezzy
