Warning light
Scorpion
57 minutes ago, Scorpion said:
Have just picked up my 350z from winter storage and noticed its Malfunction Indicator dash light is on. Any ideas what brings that light on?
Lots of things. As said code reader YOU WILL NEED IT AGAIN !
Problem solved. Had it diagnosed as you guys suggested and problem was as it had been sitting in storage for a while the battery was low so the EMS backup wasn't kicking in. Doctor said to trickle charge battery and check it. Phew!
Are there any of these code readers available that would work with 350z?
Thanks for advice.
My OBD dongle (ELM327) will only read engine codes, it's a bluetooth version & they're only about £10, I use it with the Torque Pro app, Piston & OBD Scanner. For all the other stuff I have Nissan Datascan.
