350z HR Change Log
PlanGT
  • 1 month later...
A few more bits done over the last couple of weeks. The black wheels are finally gone and I couldn't be happier with my colour choice 😁 Also added some clear JDM reflectors and a stubby aerial. Finally gave the whole car a 2 stage machine polish and wax which has really made the pearl white shine! A couple of pictures below from before and during a good drive out around Yorkshire Dales/ North Pennines over the weekend.
PXL_20230528_085342270_edit.jpg.cbb6a4f56e4b0255c6fb0bb595eb407f.jpgPXL_20230525_161323851.jpg.28bf9f0cfd9729bc0fb5afc4ecb7913e.jpg
26 minutes ago, davey_83 said:
Oh nice, sort like a champagne colour. Take it these are painted rather than powder coated as the centre caps are matched.
Thanks and yes I believe the colour is paint 😁 The caps are a little bit off in person but I can live with that!
  • 2 years later...
So... it's been a little while due to life forcing the Nissan to take a back seat. However yesterday saw a few bits done that I've been meaning to get around to for a while!
First up, wheel spacers. After 2 and a half years of "encouragement" by @Stutopia and a number of other ex-Zed owners, I've finally gotten around to it 😅 I went with the tried and tested 25mm rear/ 20mm front for the standard RAYS. I'm very please with the resulting stance :thumbs:
Next up, some heavy duty boot springs off eBay since the boot was failing to pop open. It would seem a previous owner had already put washers in in attempt to give them some more life... This was a bit of a faf of a job, since the circlips holding the spring in place were tiny. I got there in the end though so now the boot has a nice pop and much easier to open.
PXL_20250726_132824739.jpg.696de19aebdbc52bcedc749965e56808.jpgPXL_20250726_123929182.jpg.10006372d5b443150c746e1f301aecf9.jpg
The final job was a wiper delete kit which I've finally got around to fitting. I bought it off eBay a couple of years ago and I have to say I'm really impressed by the fit and finish of it. Ideally I'd have it colour coded but that's a job for another day!
Kit + Before.
PXL_20250726_141505748.jpg.74f1d18f07b02faea2933b4df9f9f31a.jpgPXL_20250726_1417318954.jpg.d783e0e0598bce39ec3878ff2d7b49c1.jpg
After. Much cleaner look imo 😁
PXL_20250726_144407554.jpg.90fd7d974615f06caac7466da2db5e0c.jpgPXL_20250726_1444333873.jpg.7fb387edc4b1fa8d165dee199b7f578e.jpg
Of course, you have to get out an for evening drive to test your wiper delete is working as expected, right?
So today's job was to give the interior door handles and vent surrounds a lick of satin black paint as they were looking very scratched up. A couple of hours of a job, right?
I'm not sure if this is the factory Nissan stuff or someone has used a plastidip type product in the past but it was absolutely awful to try and remove. I tried some light solvents, sanding (which just immediately clogged the paper) then ended up using a plastic razor blade to scrape it. It was like trying to remove wax crayon! The driver's side handle was inconsistent and sections were absolutely rock solid, hampering things further. I'm sure a more experienced Zed owner will know the secret sauce to getting this stuff off 👀
In my inexperience, I thought the white colour was down to bare plastic - it turned out to be a primer which only on the drivers side, reacted with the adhesion promoter or primer I had used. So, back to square one but this time scraping wrinkled primer off.
I got there in the end and whilst it's a massive improvement on how it looked previously, I'll probably be redoing this to get a neater finish.
Before:
Paint (crayon?) removal:
PXL_20250801_182002702.jpg.4d2b215b0f864f35af385c11ca9bad3b.jpgPXL_20250802_101548426.jpg.6a20505f86ed5a58294725fb6b7bcff2.jpg
Completed passenger side:
PXL_20250802_141522795.jpg.d92355b67b47d2ffff16cddcee52b720.jpgPXL_20250802_141542696.jpg.0660d9fcd141127461fcc38645ce71cf.jpg
Completed driver's side:
PXL_20250802_185028770.jpg.5628455cb78cfe8bbb4a50947466019f.jpgPXL_20250802_185056289.jpg.f36f70a5e655690ba1f09fe8639f7813.jpg
  • Like 5
