Immobiliser problem intermittent + remote not working
Hi guys
i have a starting issue. The car just wouldn’t start and it sounded like no fuel was coming through. I pulled the starter motor fuse and it was ok so I put it back in and the car started. I thought that was the end of it.
Later on it done the same thing, I pulled the fuse, it didn't make any difference, I pulled it out and put it back again and it started.
My friend scanned the car and it was showing immobiliser problem not fuel pump. I then realised I’d also lost the remote central locking so I’m guessing that could be related? I tried doing the key fob reset (turn key to on position 6 times etc) but that didn’t work.
So it seems there’s an intermittent immobiliser fault and to reset it I need to pull out a fuse and put it back in. Obviously I can’t live with it like this.
Could anyone advise what I’d need to check or replace to get this problem fixed please? Any advice really appreciated
Thanks
Okay, the easy things first.
Have you tried your spare immobiliser key fob?
Are the batteries good in the immobiliser key fob?
Is your car battery in good condition?
Hi. Yes I tried the spare key fob and no difference. I don’t know how old the batteries are in the fobs. I can try and replace the batteries tomorrow.
I have a new battery in the car so it wouldn’t be that
If it’s not batteries in the fobs where would be next to check?
Thanks mate
I got the key fob batteries and it’s sorted the remote central locking issue but the not starting/immobiliser issue remains
The car will only start if I remove the 15 amp fuel pump fuse and put it back in again. Then it may start 4-5 times without issue until it happens again and I need to remove and refit the fuse once more
Any advice on how best to tackle this please anyone?
Thanks
