Kryptek49 Posted March 15, 2019 Posted March 15, 2019 The clutch fluid on my HR is looking very brown, so I've just ordered some Motul RBF 600 so I can flush it out myself next week. I've seen in a few videos of people changing fluid in a 370z (same as HR i believe) that they drained the reservoir completely and then cleaned inside it with a lint-free cloth. Doesn't this introduce air into the system though? Which then causes alot of problems trying to bleed the clutch? If I don't drain the reservoir fully, how am I meant to clean the dirt from inside the reservoir? Thanks in advance Quote
ZMANALEX Posted March 15, 2019 Posted March 15, 2019 Siphon 80% of the old fluid from the reservoir using a syringe. Fill the reservoir with fresh fluid and using a small toothbrush gently scrub the inside of the reservoir. Siphon again leaving about 20% of fluid in the reservoir. Top up and bleed. 3 man operation. 1 on the pedal, 1 on the reservoir and 1 on the bleed nipple. DO NOT LET THE RESERVOIR RUN DRY 1 Quote
Kryptek49 Posted March 15, 2019 Author Posted March 15, 2019 Perfect thank you, that's exactly what I needed. I'll only have my other half to help me, so I'll have to keep a very close eye on the reservoir. Quote
