MattRwebB Posted September 17, 2018 Posted September 17, 2018 My 57 plate HR is being a bitch (vision attached) It won't start when turning the key, no starter motor noise just all lights and screens turning off. I did have to pump the clutch pedal a few times but now it's just luck and 2-3 mins of shouting at it I was thinking it Could it be the battery In the key fob for the immobiliser ? Or a switch in The clutch pedal or just some sort of re set ?? I'm not sure I'm just hoping it's a common thing and and easy fix?? Quote
Keyser Posted September 17, 2018 Posted September 17, 2018 Maybe a sticky starter solenoid, looked like battery was flat but when it fired it was fine so I'd say clutch switch as it seemed to start straight away after you lifted and pressed it again. Could be a bad contact in the switch or I think that switch activates a relay that alows the starter motor to "go live" so that is worth checking as well. Quote
MattRwebB Posted September 17, 2018 Author Posted September 17, 2018 I might try shorting the switch so I don't need to push the clutch that will rule out switch if it still dosnt work Quote
ZMANALEX Posted September 17, 2018 Posted September 17, 2018 As what Keyser has said, looks like it may be the switch. Switches are in stock if required. Quote
MattRwebB Posted September 17, 2018 Author Posted September 17, 2018 How much posted ? I'm going to try shorting it first but just so I no Quote
