slipstream Posted July 22, 2018 Posted July 22, 2018 I had my oil gallery gaskets done on my HR and now my pressure seems to be dropping again, the garage suggested doing an oil change which helped for a couple of weeks but it has dropped again so am back to square one any one have any suggestions on my next move ? Thanks Quote
G1en Posted July 22, 2018 Posted July 22, 2018 That suggests to me the pump is on its way out but there should be more informed members along soon. Best of luck sorting Quote
HiddenWomble Posted July 22, 2018 Posted July 22, 2018 Could you put some numbers to that? might help the resident gurus shed more light on the potential issue Quote
nissanman312 Posted July 22, 2018 Posted July 22, 2018 6 hours ago, slipstream said: I had my oil gallery gaskets done on my HR and now my pressure seems to be dropping again, the garage suggested doing an oil change which helped for a couple of weeks but it has dropped again so am back to square one any one have any suggestions on my next move ? Thanks Could it be a potential issue with the work that was carried out ? Just putting it our there ? Quote
slipstream Posted July 22, 2018 Author Posted July 22, 2018 They are a trader on here so I would think the work was carried out correctly, well I hope so Quote
nissanman312 Posted July 22, 2018 Posted July 22, 2018 31 minutes ago, slipstream said: They are a trader on here so I would think the work was carried out correctly, well I hope so In that case I'm sure it was Quote
slipstream Posted July 23, 2018 Author Posted July 23, 2018 On 22/07/2018 at 11:58, HiddenWomble said: Could you put some numbers to that? might help the resident gurus shed more light on the potential issue on cold start up it will be 118 which is good, normal driving around 28 again good, long drives or spirted drives it will drop to 15-16, so am going to change oil pressure switch as advised and see what happens, and one other thing I hear people say is 6th gear at 60mph = 60 oil pressure and that's seems ok to. Quote
