arif_manji Posted April 9, 2018 Posted April 9, 2018 Hi Guys, Very odd one, I took my 2009 350z HR which has covered 35,000 miles. Everything was fine, he was really pleased with the car. He then took me to the car and showed me that the front driver side bush is coming out of the suspension arm? (apologies if I haven't got the correct name for it). It passed as it didn't effect the test but something i need to address. What's the best way to address this? Replace the complete arm, replace the bushes etc. And why would this happen? These are pressed and not meant to come out are they? Pictures below: Any advise will be appreciated guys. Cheers Quote
ZMANALEX Posted April 9, 2018 Posted April 9, 2018 That is your compression rod bushing and is definitely an MOT failure. It is a wear and tear item and is a common failure. New bushings are in stock but you will require a commercial press to remove and refit the bushing. Also in stock are new arms complete with bushings and ball joints, which is the easier option. Just drop me a PM if I can help further. Alex. Quote
arif_manji Posted April 9, 2018 Author Posted April 9, 2018 42 minutes ago, ZMANALEX said: That is your compression rod bushing and is definitely an MOT failure. It is a wear and tear item and is a common failure. New bushings are in stock but you will require a commercial press to remove and refit the bushing. Also in stock are new arms complete with bushings and ball joints, which is the easier option. Just drop me a PM if I can help further. Alex. Hi Alex, Thank you for your message. The parts you supply, are they the Genuine Nissan parts? If so, could you send me a quote on the complete arm please? Cheers Quote
arif_manji Posted April 10, 2018 Author Posted April 10, 2018 I'm a little confused, which part from my picture above is the part below? Quote
Jack94 Posted April 10, 2018 Posted April 10, 2018 The compression rod (banana arm) is the bottom of them 2 pictures Quote
arif_manji Posted April 10, 2018 Author Posted April 10, 2018 2 hours ago, Jack94 said: The compression rod (banana arm) is the bottom of them 2 pictures Thanks mate Quote
