clutch slipping only in reverse gear
Gabor
Hi guys,
I have a mysterious issue with my 350Z, my clutch is slipping badly, but only in reverse gear.
I never had a single slip in any forward gear, not in a traffic jam or when I was pushing the car hard, but in reverse gear even if I try to reverse with nearly zero throttle and I'm very gentle on the clutch pedal, I immediately hear the whining and in 3-4 seconds I smell the burning clutch.
How is that possible? I believe I need to replace it as this is is definitely not normal...
I have an unknown single mass flywheel and performance clutch fitted by one of the previous owner (no receipt about it unfortunately).
Thanks for the ideas.
  • 3 weeks later...
  • 1 year later...
On 13/01/2018 at 17:00, Gabor said:
Hi guys,
Is this still alive? Im getting the same issue except it only happens when im reversing uphill. It sounds like a whine when your clutch is slipping, except ive never had any issues on a flat surface nor driving forwards uphill.
