Hi Redsky key turns ok.it doesn’t fell as if it’s a mechanical lock was wondering if it could be it only works if it has 12 volt supply.my car battery I know is dead.need to gain entry to charge it.sorry for the delay after you response any help would be much appreciated
Call the AA or similar, by the time you fart about with a slim jim or try to access the bonnet pull cable from the wing arch, you will be much quicker and probably cheaper using the AA.
Yeah I agree with alex call the AA or similar. If the lock wasnt turning i would have suggested some wd40 or something to get it moving but if its entirely dead call the AA.
