Rear brembo brake disk replacement guide?
Do you need one??
Wheel off, caliper off, release/slacken off handbrake shoes (through the rubber plug in the disc there's a cog to turn) and then pull the thing off (might be a screw holding it on, can't quite remember)
I've changed mine before... which means anyone can! :) The only problem you will run into is if you leave your handbrake on (or in gear). As you are lifting the rear wheels make sure the fronts are chocked so your car can't roll away! :thumbs:
