D1 throttle control
Ricksta1980
I hated mine with a passion. Brilliant for about a week, then you realise it's just making the throttle too stabby and sensitive and you lose the ability to control the car properly at the higher settings. I took mine off, and would never go back there again.
If you do decide you want one, you can 100% fit it yourself, it's a piece of cake. I believe Tarmac on here sells them too :)
I believe a couple of the traders on here sell them. Adrian at Torquen does but he's just had some bad luck with a fire at his store. Should be easy enough to get one though. Try Chris @ tarmac sports. He might have some in stock.
Fitting is fairly straightforward to do yourself mate. There is a how to guide on here that Hodaka has taken the time to provide the community, I'll try post a link wen I find it. Hardest part of fitting is removing the pillar trim but that's if u decide to run the cable that way.
Hope this helps.
Edited by STYLZ
