Having my BC coilovers, sway bars, Adjustable camber and toe arms fitted at the garage today. Mechanic had a few problems as he is not familiar with the zed set up. I think I have cocked up on ordering toe arms as they won't fit with the rear coilovers. Is this correct?
A= camber arm
B= Toe arm
Also can anyone ID this bush as it needs replacing?
Many thanks in advance
Edited by taybo
Depends if you have true coilovers or separate spring and damper on the back.
If the latter then no you don't need them.
I have just bought BC Racing coilovers with the separate spring! :headhurt:
What brand are the toe arms?
