Easty Posted November 17, 2016 Posted November 17, 2016 So had my belts changed and within a few weeks my car snapped one and spat both belts off...... Put new belts on and but iv got a little bit of end float play in the Power steering bump..... Question is, is it meant to be there or not. Now the new belts have started to squeal on start up till they get warm and then stop...... Any ideas please it's bugging the hell out of me!! Thanks guys Quote
mr v6 Posted November 18, 2016 Posted November 18, 2016 What brand of belts did you fit? I replaced the longer one with a Gates & the shorter with a Conti one. Double check your tension too as that will cause some squeal, unless they're the wrong length? Quote
Easty Posted November 20, 2016 Author Posted November 20, 2016 Whats end float play? When you hold the pulley it moves in and out ever so slightly..... (in and out) Quote
