Water drainage on boot lid.
Is this normal?
It last rained here in Manchester yesterday, just an hour ago I opened the boot & water ran out of what seemed to be a channel behind the outer rear window seal on the inner side of the boot lid skin, causing the water to run out & over the rear 1/4 panel.
If that makes sense?
Water will collect where my boot spoiler meets the boot.
When you open the boot this will flow up the rear window and drip down the sides of the rear quarters.
Although I have a larger Nismo rear wing I'm sure you would get similar on a standard rear lip spoiler.
The water isn't collating on the spoiler though, it seems to be running from the vertical seals on the underside of the rear screen.
