Another Iridium Plug Question...
Ok, so I've just ordered some NGK IX iridium plugs and they come in varying heat ranges 5 to 8. What does that mean?
I've gone for heat range 6 is that going to be ok for my 06 pre uprev?
Sent from my SM-G935F using Tapatalk
Why did you not just order the plugs recommended for your engine ? Loads of information on here about the correct spark plugs to buy or just ask a trader on here that will give you the answer?
You will need heat range 5 for the VQ engine, the numbers are the heat range of the plug, and should be kept at std range unless the engine is SC or TC.
Edited by Tricky-Ricky
Yep. I'm N/A and only engine mod which will soon be fitted is the titanium zorst system.
I'm trying to pin down a decent plenum spacer kit ready for the uprev map.
