Looking for some info when installing my harnesses.
Anyone have any idea what the bolt size of the lower seatbelt mount is? Wanting to install eye bolts so the lap strap can snap on at there
I have used my harnesses fine on mine.
How can I use the original bolt if I have no hole to snap the harness to?
most legit harnesses come with eye bolts but im also 90% sure a modern car seat belt bolts are interchange as when i order my luke ones i got eye bolt with them and they fit without me giving car details
Hardest part is where to chose to mount the eyebolt and plate on the trans tunnel.
i just put mine in my seat subframe
Most dangerous thing you can do!
See I don't think u get eye bolts with the takata harnesses.
So I assume it's just a 7/16" unf then. Anyone any idea of the length? I would check myself but I'm away with work at the moment.
I just bought standard length ones from GSM Performance.
I've been looking on there and there is 4 different lengths to choose from for the single bolts. For the bolt and plate that's one single length
Just measure the length of the OEM bolt and match it as close as possible mate
I would but I'm offshore at the moment so can't :/
Was just trying to get everything ordered for when I get home
I ordered quite short ones. Work for me í ½í±í ¼í¿»harness' haven't moved one bit!
Fancy helping me out when you have a moment and measuring it for me?
I ordered quite short ones. Work for me í ½í±Â🏻harness' haven't moved one bit!
I would love to but I'm going on holiday tomorrow dude. I believe they're about 8cm though
Just remind me where the stock seat belt buckle is bolted to
Completely different with stock seat belts. They're designed in a certain way hence why every road going car has them. And also you're securing a buckle not a complete independent lap strap. Seen various harness companies say not to mount to seat bracket. Hence why they sell the load spreading plates and eyelets.
Use at your own risk ðŸ‘ðŸ»ðŸ‘ðŸ»ðŸ‘ðŸ»ðŸ‘ðŸ»
