lotuscc Posted January 22, 2008 Posted January 22, 2008 One set of brand new Kinetix hi-flow cats. £265 + £12 p&p or collect for free. 02-06 350Z (includes rev-up) These are the very latest 3rd generation Kinetix cats and include fitting bolts. Less than 1/2 the weight of standard cats (approx 7 kg). Info from Kinetix website: NEW improved design Complete set! High flow catalytic converters that will pass emissions testing for 350Z and G35 (2dr and 4 dr) 03-06 *New and Improved with more installation clearance and long term strength ! ** "Spun" cat design has a full stainless construction for much higher strength and flow ** More clearance for easier installation The factory catalytic converters are well known as the biggest "choke point" in the factory exhaust system. These high flow stainless spun catalytic converters blow away the stock converter flow rates while still maintaining legal emissions levels. Constructed with stainless tubing and 3/8" stainless flanges (converters are aluminized steel). Fully TIG welded and true mandrel bends used throughout. These converters will bolt up to any header (factory or aftermarket) and any exhaust (factory or aftermarket). These pipes also retain the factory Oxygen sensor location and WILL NOT THROW A CHECK ENGINE LIGHT!!. Expect great performance gains from these converters as they have dyno'd between 6-8 hp at the wheels on factory 350Z's. They only add a slightly more aggressive exhaust note and do not have the pesky "raspiness" between 3-4k rpm that is seen with straight through test pipes. Quote
Sarnie Posted January 22, 2008 Posted January 22, 2008 Cheaper to buy direct: http://kinetixracing.com/index.asp?Page ... dID=5&HS=1 Quote
lotuscc Posted January 22, 2008 Author Posted January 22, 2008 Cheaper to buy direct: http://kinetixracing.com/index.asp?Page ... dID=5&HS=1 If you live in the US!!! Every 350Z part seems to be cheaper there. Shame about the VAT, duty and postage we have to pay. Quote
P15UL T Posted January 22, 2008 Posted January 22, 2008 i imprted a set myself and they cost a little more than this after paying taxes etc, so they are worth the money to get them quick and without any hassles Quote
Sarnie Posted January 22, 2008 Posted January 22, 2008 Cheaper to buy direct: http://kinetixracing.com/index.asp?Page ... dID=5&HS=1 If you live in the US!!! Every 350Z part seems to be cheaper there. Shame about the VAT, duty and postage we have to pay. Mine came without any VAT or duty and P+P was $60 Quote
