Y5ave Posted March 19, 2016 Posted March 19, 2016 Hi does anyone know why the clutch slave cylinders fail on 350zs ? I've heard The hose can get very hot and this damages the piston seals because the fluid Gets heated . Quote
GMballistic Posted March 19, 2016 Posted March 19, 2016 I'm assuming you meant to post this in the 350Z area so I've moved it here. Â Hopefully someone more knowledgeable on the subject will be along shortly. Â Welcome aboard btw. Quote
Y5ave Posted March 19, 2016 Author Posted March 19, 2016 Thanks I'm a newbie as you can see already ! Quote
ZMANALEX Posted March 19, 2016 Posted March 19, 2016 Hi does anyone know why the clutch slave cylinders fail on 350zs ? I've heard The hose can get very hot and this damages the piston seals because the fluid Gets heated . Â Your assumption is correct. Â The rubber hose and oem fluid can not handle the heat from the exhaust/cat on the DE. Â Braided line, high temperature fluid and a new oem slave usually fixes the issue. 1 Quote
GMballistic Posted March 19, 2016 Posted March 19, 2016 ^^ ...And there is the more knowledgeable man on the subject. Quote
