Posted (edited)
Passenger window goes up and down fine when using passenger switch. But drivers side passenger switch, it'll go down but then won't go up. You can hear it trying. But won't move upwards?! I thought if it was normal motor fault that's common on the zeds that it wouldn't go up no matter what switch used?!
Edited by Luke350
thinking from a pure electrical view it sounds like not enough power going to from drivers side switch could be a bad connection on switch either the live or the switched live have a look at the connections you can see and remove the plug and check the pins are all ok
Posted (edited)
I think I must have the same issue. I thought the motor was broke, most of the time it just doesnt move at all, but some times it has the power to go down, but goes up reaaallllyyyyy slowly - so would you suggest we have the same problem? (mine struggles with both passenger and drivers switch for the window)
Edited by GeorgeW
Yes quite possibly mate. Could maybe be a bad ground or loose connection on the switch. I just automatically think motor because they are a common problem.
