Button question.
Quinster
The mirrors should be heated to from memory. The button nearest the drivers seat heats the bit you sit on only not the back rest. Turn it on, when it feels like you have soiled yourself it's done it's job 😄
Thanks.
Is there a button for the mirrors too?
p.s this is great finding out all these things.
lol
My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing?
Not sure but on mine (import) it's a Snow/Power button.
Probably the same as yours.
Only down side is, i keep knocking it onto snow when i stop at lights etc.
Pulls away slowly all the time.
Need to knock it into neutral and then switch it off.
Am i right in thinking that is only on automatics. Otherwise it is blank
Snow button? I drove a 350Z in the snow when I first owned one ten years ago and if that button works it would keep the doors locked and not let you get in :lol:
The only snow button in a UK spec car is the traction control - better switch it off in the snow to avoid getting stuck... if you haven't already met a sticky end that is...
Ah, that might be it...
I never mentioned it was an automatic.
It has Traction control as well.
Is it a manual then?
http://www.350z-uk.com/topic/16915-snowatpower-button-whats-it-do/
Think your missing the roof down button
My roof button is on my right, next to the steering wheel.
