***TORQEN*** LOWEST PRICE 370z oil cooling options
Posted (edited)
1. Mishimoto Oil Cooler Kit - 19 row
£399
2. Z1 Oil Cooler Kit + Thermostatic Sandwich plate + Setrab Core - 19 row
£379
3. Z1 Oil Cooler Kit + Thermostatic Sandwich plate + Setrab Core - 25 row
£429
4. Z1 Oil Cooler Kit + Thermostatic Sandwich plate + Setrab Core - 34 row
£499
5. Stillen Gold Performance Series Oil Cooler Thermostatic - 25 row
£329
6. Stillen Power Steering Cooler Kit
£169
7. Stillen Transmission Cooler Kit
£279
8. TiTek Magnetic Drain plug M12x1.25
£15
9. NRG 12x1.25 Magnetic Oil Drain Plug
£13
Info:
19 Row (13" x 1 1/4" x 5 1/3") -- Recommended for most light street applications or applications in colder climates where less cooling is required. Will work with all aftermarket intakes.
25 Row (13" x 1 1/4" x 7 1/2") -- Recommended for more intense applications where occasional track use will be seen, also for more moderate climates. Will work with most aftermarket intakes.
34 Row (13" x 1 1/4" x 10 1/4") -- Recommended for forced induction applications, serious track applications, or in high temperature climates where extreme conditions may exist. Will require modifications to install with some intake systems.
Edited by octet@TORQEN
Are the top 3 all in kits? As in no more parts are needed and the only difference is the brand and materials used?
How many rows is the Z1 kit?
