Gearbox Issues
350zPhil
When I changed the clutch a little while ago I noticed there was a lot of play on the input shaft and sometimes when shifting it feels like the gate moves. Firstly is it likely that the rest of the gearbox will be good on an 05 plate with 55k on the clock, secondly would just changing the input shaft bearings solve the problem or am I just entering into a whole world of bother and should just get another box?
Any ideas from anyone who has experience with this.
You will always get movement on the input shaft, and the bearing only requires replacement if it is noisy or failed.
If the box is quiet and the syncros are good then just leave well alone.
Gear selection can sometimes be difficult if the selector gate plate is not adjusted properly after refitting the box, however not sure what you mean by gate movement, please elaborate.
Alex.
