Rocky4510 Posted August 2, 2014 Posted August 2, 2014 This is probably really straight forward, but where do I wire these cables? This ones for the DAB radio: This ones for the reverse camera: I know the red wires are the 12v, but wheres best to hook them up? Thanks in advance Quote
EvansJD2112 Posted August 3, 2014 Posted August 3, 2014 For the camera, I suspect the cable with the yellow phono is to go to your head unit so it can detect you going into reverse and showing the video feed. I would wire +ve to the reverse light +ve and -ve to earth. For the DAB aerial, just wire it to +ve feed that is switched. Have DAB myself and gave up on all internal aerials as they are pants. Eventually replaced the OEM aerial for a body mount DAB one. Full signal all the time now. 1 Quote
Stutopia Posted August 3, 2014 Posted August 3, 2014 Have a read in here on routing and wiring rev cam. http://www.350z-uk.com/topic/56481-kenwood-ddx-4028bt-rear-cam-install-–-superguide/ 1 Quote
Rocky4510 Posted August 3, 2014 Author Posted August 3, 2014 Thanks guys, I'll have a crack at it this week Quote
