LukeD Posted July 16, 2014 Posted July 16, 2014 Is it normal for the fan to kick in relatively quick, I mean after about a minute or 2 when stationary when up to temp obviously? Quote
M13KYF Posted July 16, 2014 Posted July 16, 2014 yep. You will notice it turns on when the car comes to a stand still and turn back off as your moving off. Also dependant on aircon being on or not Quote
WhackyWill Posted July 16, 2014 Posted July 16, 2014 Also check you coolant level.. (when engine is cold...!! ) Quote
LukeD Posted July 16, 2014 Author Posted July 16, 2014 Coolant level is spot on, ah so it's like a safety thing once came to a stand still? Quote
Keyser Posted July 16, 2014 Posted July 16, 2014 It's a heat thing and it's been bloomin hot lately Well it has down here Quote
350zedd Posted July 16, 2014 Posted July 16, 2014 You get no cooling through rad when stood still, so soon heats up. Fans will cut in at a pre set temperature to prevent overheating Quote
Nick350z Posted July 16, 2014 Posted July 16, 2014 (edited) One of the engine fans will come on as soon as you put the air-con on as well. I found that out after I thought I had a fan issue and someone on here kindly pointed that out for me :-) Just noticed M13KYF also pointed that out as well :-) Edited July 16, 2014 by Nick350z Quote
