Bit of a write up on "Nico" club that should help understand what they do. I know the guys at Horsham Developments did some testing on whether they had any effect or not, and there tests showed a positive improvement.
HERE is the Horsham Dev info
If your std earth points are corroded, which on most 5 year + old cars they are you will probably notice and improvement on fitting a grounding kit, however you will likely notice the same improvement if you go around the std earth points and give them a good clean, in which case you save yourself £20-60.
  • Like 2
