TDI Posted August 1, 2007 Posted August 1, 2007 Hi, I hope you guys may be interested in a project we currently have under construction. It's not actually a 350Z - it's a G35 Skyline but I hope there is enough similarity to have some appeal to you. I'll post up in a blog form if I may? Info to follow shortly Quote
Chesterfield Posted August 1, 2007 Posted August 1, 2007 Sounds great! Although Im more comfortable with doing cosmetic mods rather than mechanical, (and it takes me all my time to get round to doing anything on the cosmetic side). Im still keen to read about projects like this its great to get an insight into how these things are undertaken etc. Im sure there are others that lik to read about these projects too. Dont forget you have your own TDI blog area where you can administer the posts... Quote
Chris`I Posted August 1, 2007 Posted August 1, 2007 Sounds interesting, make sure you post loooooots of pics Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 Dont forget you have your own TDI blog area where you can administer the posts... Aaaahhh - silly me If an Admin feels this topic will more appropriate in another section - please feel free to move it. Thanks Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 Here she is - the apple of our clients eye - a very nice G35 Skyline with around 20,000 miles under her belt Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 Here's the standard engine having just been removed from the car. Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 This is the old engine partly dismantled Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 The pistons crowns showed a remarkable amount of carbon deposits for such a low mileage engine Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 Our client had reported a degree of oil consumption which explains the carbon deposits. Subsequent measuring of the cylinder bore integrity revealed an excessive amount of ovality. Quote
Jacko Posted August 1, 2007 Posted August 1, 2007 The pistons crowns showed a remarkable amount of carbon deposits for such a low mileage engine Any particular reason for this? Running on 95 RON or something, just poor quality fuel etc? Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 Now for the interesting bits ..................... Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 Cosworth forged steel H section connecting rods Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 .........all 6 of them to replace the puny standard rods........ Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 The set of Cosworth forged pistons.............. Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 These feature a very low expansion material that allows for a tight cylinder bore clearance to reduce noise and oil consumption, a polished crown and patented anti detonation grooves Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 .....and an anti scuff surface treatment on the skirts Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 Cosworth crank case studs maintain helps keeps the crankshaft where it needs to be Quote
TDI Posted August 1, 2007 Author Posted August 1, 2007 Cosworth head stud kits stops the heads lifting Quote
