wizurd Posted April 25, 2014 Posted April 25, 2014 Evening all. I've got two silicon hose pieces that connect the air intake tube to the throttle body and the other end to the maf housing. Don't need them anymore so happy to give them away to someone that needs them. If you're local can simply collect otherwise would just need money for p&p. I think p&p would be around £4. They're in an ok condition. The hump connector has a 1cm scratch in it that you can see in the one pic. Sorry pics aren't the greatest. Approx dimensions are: Hump connector Length 10cm External Diameter 8.5cm Internal Diameter 7.7cm Straight connector Length 7.6cm External Diameter 8.6cm Internal Diameter 7.6cm
wizurd Posted April 25, 2014 Author Posted April 25, 2014 newport, se wales. I'll be at Japfest this year so that's on 10th May. In case thats easier for you or anyone else that wants them
