JEMAN Posted March 30, 2014 Posted March 30, 2014 Hi all, The engine light that came on was due to a cam shaft sensor on the code (drivers side). They did try at first by checking the old sensor which did work for a few days, but the problem came back. So now the garage I use have recommended a new sensor to be fitted. My question is can this been hopefully down to the sensor. The car runs fine, then all of the sudden try's to cut out and with a quick dip of the clutch, and a blat of the right foot it fires up and is fine but with the engine light, and esp/anti skid lights on.......anyone had this issue ?????? Quote
Hammerz Posted March 31, 2014 Posted March 31, 2014 Yeah, me yesterday too (have you been driving my car !?!?). My engine light, esp etc came on. I did the peddle dance to reset the ecu to see if it came back. Looking to get it in the garage asap to get checked but all searches on here point towards the cam shaft sensor regardless of other linked issues (my windows stopped working too) 1 Quote
StevoD Posted March 31, 2014 Posted March 31, 2014 (edited) yea i had this issue slip and vdc lights on mid track day at snetterton , then a few times after on the road over a few months then got a Sensor from Zmanalex and been fine ever since Edited March 31, 2014 by StevoD 1 Quote
JEMAN Posted March 31, 2014 Author Posted March 31, 2014 Thanks for the heads up guys, it's good to know that it the sensor I'll keep you posted on the outcome Quote
samsniss350z Posted April 2, 2014 Posted April 2, 2014 You can't go wrong with ZmanAlex. There are a lot of cheap manufactured sensors on the market and unless you know just what you're buying you could be into a whole heap of trouble. Quote
