Fitted decat pipes with spacers and still getting P0037, heater control circuit low bank 1 sensor 2 fault, just wondering exactly which O2 sensor this is referring to? I have reset multiple times and within 5 miles the lights back on, iv also stuffed wire wool in the spacers but hasn't made and difference so I'm thinking it's a genuine faulty sensor just not sure which one.
Any help is much appreciated.
Cheers
Bank 1 = Drivers side (cylinders 1,3,5)
Bank 2 = Passenger side (Cylinder 2,4,6)
Sensor 1 = Nearest the engine on exhaust manifold downpipe, before CATs
Sensor 2 = Rear most, fitted at the rear end of the Cat/Decat pipe.
I have the same one up - P0037.
Tried with / without spacers - and it still pop up.
Reckon I might have damaged sensor will removing it from original cat - that side (drivers) was a tight bugger to get off, require liberal use of hammer? :wacko:
