Hey guys , ive jus got my late 2004 350z and she has put the ecu light on and the fault is p1706 p/n switch, anyone know how to solve this problem, and also the bloody airbag light has just started flashing . any help would be very much appreciated
hey guys, jus got the airbag light sorted , cleaned the plugs under both seats and one was defo corroded but all good now , reset the the srs and thanfully all is good now. does asnyone know the location of this p/n switch thats showing up an ecl light.
Cheers Niall
Forgot to say that the Neutral Position Switch is located on the right side of the transmission. It is above and just forward of the transmission mount. There is also a switch on the left side that is for the reverse lamps. Make sure they are both plugged in.
I am assuming that your reversing light is not working.
Alex.
Edited by ZMANALEX
  • 1 year later...
thread revival i know, but my car for the last two days is throwing up this error P1706 . I cleared the ecu using torque, but keeps coming back. The reverse light is working. I found a video of a guy with this error on youtube but it was a nissan ultima. Is a straight replacement? can it be taken out cleaned then put back? Can i continue to drive the car like this?
Does your car have an automatic or manual transmission? With a manual transmission the fault refers to a switch as described above. With an automatic, the park/neutral signal is generated in the Transmission Control Module and can effect starting and cruise control operation.
Cars a uk manual. So it's not serious?
No. I believe the only thing the switch does is disengage cruise control if you happen to shift without using the clutch.
forgot to ask how do i get rid of this? can it be cleaned and put pack? or is it a direct replacement? I can't get the light to go away every few days keeps coming back.
dont know about the above, but if the airbag light comes on again do the ignition on and off routine to clear it. Its a common thing on here. Plenty of info on the tube of You !!!
A direct replacement is probably best. Until the problem is fixed you will keep getting the light every few days.
