Jared350z Posted August 30, 2013 Posted August 30, 2013 Hello again, I thought I had a problem before with my TCS button, but after some scientific testing on a roundabout found out that is does work but the lights on my dash don't. SO this means I cant tell if my TCS is on or off, which sucks! Does anyone know how to fix this before I go and end up breaking my dash trying to fix it. cheeeeers Quote
KyleR Posted August 30, 2013 Posted August 30, 2013 It's always on as default unless you manually turn it off. So from a safety POV it's fine. Fuse? Quote
Jared350z Posted August 30, 2013 Author Posted August 30, 2013 It's always on as default unless you manually turn it off. So from a safety POV it's fine. Fuse? I dont like having it on ha ha I like being able to feel the car, not having an ECU tell me to chill out, thats what women are for ( not sexist ) Might be a fuse but surely the other light would be out to?? Quote
A9H-RX Posted August 31, 2013 Posted August 31, 2013 It's always on as default unless you manually turn it off. So from a safety POV it's fine. Fuse? I dont like having it on ha ha I like being able to feel the car, not having an ECU tell me to chill out, thats what women are for ( not sexist ) Might be a fuse but surely the other light would be out to?? Might be a bulb in the clocks? Only a 7/8 min job to take off.. 1 Quote
