Richparry2009 Posted August 20, 2013 Posted August 20, 2013 New to the zed world - Sorry I know this is on here somewhere, I can't find the link to some simple instructions? is it also easy to take the door cover off? I also wondered if the window will go higher when you reset it or is it at the max when you hold the window switch up? as I think it could go another 3 or 4mm higher. I want to try this before buying a window/door seal as it seams to be worn! Cheers. Quote
Stutopia Posted August 20, 2013 Posted August 20, 2013 Door card off in the first part of this: http://liljerk.morpheus.net/350Z/front_speakers/ Window reset: http://www.350z-uk.com/index.php?showtopic=55900. Quote
Richparry2009 Posted August 20, 2013 Author Posted August 20, 2013 Nice one it explains the whole lot- see what I can do at the weekend and hope it solves the wind noise! Cheers. Quote
