Eibach spacers - stud size
HaydnH
Hi CS,
If they're not fitted yet, is there anychance you could have a look and guess the shape/size of the bolt head and also the washer/nut? I'm beginning to think that this is going to be more hassle than it's worth just trying to find the right bolts! :(
Haydn.
Can you not just measure the oem nuts that fit into the eibach spacers then get some aftermarket ones that are the same length as oem?
The bolts & nuts that hold the outer eibach studs to the spacer is what I'm after replacing, they're from Eibach so not OEM. I could measure mine but that would require taking a wheel off, removing the spacer, removing a stud, measuring the stud, reassembling and fitting... then buying a sample stud and repeating the process... which I may have to do eventually anyway but I'm at work. ;)
