Speaker wire colour help
Patch
Then this on another forum
Radio 12v yellow/green + radio harness
Radio Ground (chassis)
Radio Ignition purple + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/white + radio harness
Power Antenna green + radio harness
LF Speaker +/- blue/white - blue/red +,- radio harness or amp under rear deck
RF Speaker +/- white/black - blue/black +,- radio harness or amp under rear deck
LR Speaker +/- green/yellow - black/yellow +,- radio harness or amp under rear deck
RR Speaker +/- blue - red +,- radio harness or amp under rear deck
Then this
OK, here's the colors of the wires PRE BOSE AMP.. these are the wires you want to tap into if you want to add a high lo converter BEFORE the signal reaches the BOSE amp...
AMP ON - Black/Pink
BAT - Yellow/Red
SPEED SIGNAL - Violet / WHite
Ground - Blue / Black
ACC - Violet / Yellow
Left Front + Green
Left Front - Red
Right Front + Black
Right Front - White
Left Rear + GR\rey/Violet
Left Rear - White/Blue
Right Rear + Violet
Right Rear - Lightgreen
I mean it has been ages since I had the HU wiring out but looking at the pic in the OP, you can eliminate a lot already.
Since you are looking for speaker wires, it's logical to look for a plug that has at least eight wires coming out of it, which counts out the plug on the left of the pic. Then you want to make sure that those eight wires are of the same gauge, which rules out the plug on the right in the foreground, which leaves only the plug in the background. That gives you a visual representation of the colours you need to match up, which you can cross check with the info posted in response and simple deduction leads to positive identification of what is what.
Simple really ;)
