TOM'S_ZED Posted April 28, 2013 Posted April 28, 2013 Hi folks I'm looking at buying some wheels for the 350z and need to know what tyres will fit the rim sizes are 19x8.5" 5x114.3 ET15 Front 19x10" 5x114.3 ET20 Rear cheers Quote
Neilp Posted April 28, 2013 Posted April 28, 2013 245/35/19 front 275/35/19 rear you'll be fine at those. Not sure if they will hit the arches with the offsets you are talking about though. The tcs is very happy with these tyres sizes Quote
MITZ@CougarStore Posted April 28, 2013 Posted April 28, 2013 Hi folks I'm looking at buying some wheels for the 350z and need to know what tyres will fit the rim sizes are 19x8.5" 5x114.3 ET15 Front 19x10" 5x114.3 ET20 Rear cheers We supply the same wheel specs and as Neil said, 245/35/19 and 275/35/19 is what we always use... Quote
TOM'S_ZED Posted April 28, 2013 Author Posted April 28, 2013 245/35/19 front 275/35/19 rear you'll be fine at those. Not sure if they will hit the arches with the offsets you are talking about though. The tcs is very happy with these tyres sizes what do you mean about the traction control mate Quote
MITZ@CougarStore Posted April 28, 2013 Posted April 28, 2013 No fitment issues with those at all, as above, we've supplied the very same with the tyres quoted above... Quote
Neilp Posted April 28, 2013 Posted April 28, 2013 245/35/19 front 275/35/19 rear you'll be fine at those. Not sure if they will hit the arches with the offsets you are talking about though. The tcs is very happy with these tyres sizes what do you mean about the traction control mate The tcs is programmed to measure rotational speed to determine if a wheel is slipping. Wrong tyre sizes cause it to go bonkers, throwing brakes on prematurely, cutting power when your trying to pull out a junction or round corners. Check the tyre section of the forum, plenty of info in there. Quote
TOM'S_ZED Posted April 28, 2013 Author Posted April 28, 2013 cheers my mistake thanks for the info also will come in usefull however i was out bid on the wheels , Quote
