I used the InCarTec Fascia 50-306 [DOUBLE-DIN FASCIA KIT (for MY2006 > ONWARDS)] in my HU install - see thread > viewtopic.php?f=27&t=58783
To be honest - none of the fascia kits are a 100% match to OEM (see the photos in my thread); ...and all of them end up with a small gap between the fascia and HU.
The manufacturer supplies their own 'finisher' trim - but you'll likely not be able to use that without either modifying the ICT Fascia (would require cutting down) - or you just leave the manufacturer's 'finisher' surround trim off completely; (dump it!)
If you take your time - when fitting the HU - I used little pieces of card around the HU to get a symmetrical 'gap' around the HU - the end result will be pretty good.
I know some forum members have used things like 'foam tape' to close the gap between the HU and the fascia; but TBH - if you get the HU central to the fascia - it will look nice and neat.
Good luck - and I'm sure the other forum members will be along soon to contribute their valuable advice.
Cheers
M
100th POST - Hurrah !
Must have changed your exhaust if you going to listen to music. :p:lol:
:p:p yes Chris. I'm milltek'ed up and can hear again hence the stereo/ nav. Wales will never be the same again.
@ aftershox. Thanks will take your advice. Will try to refit after I get my volume issue sorted.
Have to agree with what's been said, I've tried the incartec pioneer fascia too and couldn't get it to fit at all. A neat gap is probably the best you can hope for without fabricating a custom fascia.
DB
