No 245/35/19 on front and 275 35 19 on rear :thumbs:
+1 :thumbs:
+2 :thumbs::lol:
Won't do any harm to drive it, Just be aware that your Traction control and maybe your ABS won't be working.
Getting new tyres all round is the best decision. :thumbs:
Also get the best ones your budget will allow. ;)
I decided that after much reading to go with kumho ecsta ku31's for my road wheels. I have used then a good amount of miles now and gave them a bash on track at castle Combe. Mighty impressed even after coming from ps2's. I started reading on the m3 forums and this seemed to be what they guys used in the same sizes. Bought from camskill for 530 ish. Couldn't afford to keep putting ps2's on as I only get a few thousand out a set as I ended up using them on track as ps2's were so good. Decided to go with these to tempt me away from using them on track but thought it good to try them just to see how much abuse they could take.
Would defo recommend them as a decent budget tyre. Excellent performance in the wet, dry and cope with heat and braking well
530ish was that for all four? I was looking at falkens again because I know a few on here use them but there around 640 mark so will have a look at the ones you have if you say there good. Cheers for the help just been getting me stressed cause need it back on the road.
No probs. I got them from camskill. I'm a bit anal with tyres and even after using michelin ps2's I still rate these. Very good value for money.
Isn't 245/275 a bit fat for those wheels? I mean I know it's in the maximum limits, but maybe 235/265?
I think the rolling radius difference is still within tolerance there and I believe it's closer between the front and rear axle that way too :shrug:
Nope. 235/35/19 275/35/19 would be fine. I ran this on my 19's or a while which are 8.5j and 9.5j Nismo recommend 245/35/19 and 275/35/19 for the nismo lmgt4's
TBH 8 front, 9.5 rear are some odd sizes anyways. To me at least.
right ordering my tyres tomorrow. every time i think i know what tyres to get someone puts a different size up and makes me worry lol. so just to check what should i be getting the fronts a 8x19, so do i need 245/35r19 0r 235/35r19 and the rear is 9.5x19 so should i be getting 275/35r19 or 265/35r19? cheers people
Either. Both are within the limits.
