keiichi tsuchiya Posted April 3, 2012 Posted April 3, 2012 after installing the LSD I found after about 10000km a clicking noise coming from the tree ... What can be? bearing anti vibration or noise? or am I in danger of splitting the whole tree? the click is created only when I remove gas and reissue the command, and only above a certain power (however minimal). (I always apologize for my English but I use google translate, I'm Italian ) I thank you in advance for the advice and information. Thanks to all! Quote
was8v Posted April 3, 2012 Posted April 3, 2012 Common problem, try this first: viewtopic.php?f=9&t=60165 If that doesn't fix then replace the CV joint - Quote
keiichi tsuchiya Posted April 3, 2012 Author Posted April 3, 2012 Common problem, try this first: viewtopic.php?f=9&t=60165 If that doesn't fix then replace the CV joint - I also have the clicking noise but this is not ... This is very quiet as noise ... mine is a blow dry and strong from inside the shaft. my mechanic says it's some rubber inside ... but you say that component? PS ... I do not understand!?!? you can explain better? so before you buy something I inquire if I should try to replace it Quote
Vik54 Posted April 3, 2012 Posted April 3, 2012 Surely we have someone who speaks Italian resident on the forum? Quote
keiichi tsuchiya Posted April 4, 2012 Author Posted April 4, 2012 Surely we have someone who speaks Italian resident on the forum? Quote
keiichi tsuchiya Posted April 12, 2012 Author Posted April 12, 2012 my car stop the noise after this afternoon Quote
