A couple of weeks ago I mde a post after having issues after cleaning the throttle body and moving the butterfly.
http://www.350z-uk.com/forum/viewtopic.php?f=20&t=55949
After getting some good responses i set about doing the idle air learning proceedure. After successfully completing the pedal proceedures (several times) the idle was still high, i had lack of power and the engine was running rough.
I got in touch with a local dealership who told me the car needed an idle air reset using their machine. Being slighly skeptical i dropped in early and the technican plugged it in, cleared some codes and reset the idle air learning. I was in and out the dealership in 10 minutes.
The car now idles and runs spot on. One other problem that it has also solved is that it now never stalls from a cold start, which i'm really chuffed about.
I thought i share my experience, just incase others have a similar issue.
Top marks to Murley Nissan :thumbs:
