Carbon fibre Di-Noc wrapped B-pillars (PIC HEAVY)
Hi all,
As mentioned previously on intending to wrap my B-pillars, I have finally completed the task!
Thanks to Rich (RTBiscuit) for taking the time out on advising and helping me, I really appreciate all of his help! :thumbs::thumbs:
I removed the rubber weather strips off the pillars before I wrapped them, then used adhesive glue and stuck them back on. Is it necessary to re-apply the weather strips or are they not important? The strips are starting to peel slightly as the glue didn't stick properly. Shall I remove the weather strips completely or stick them back on as they are needed?
Photos below:
Many Thanks,
Hassan
Thanks everyone :) It wasn't as hard as I thought it would be! They do make a massive difference to the appearance of the car, especially because it's grey
Good work, happy to help,
i hope its given you more confidence to try more parts. :thumbs:
I really appreciate your help :)
Yes it definitely has! I'll probably end up purchasing some vinyl off you for other bits and bobs in the future ;)
Is it necessary to re-apply the weather strips or do people just apply the B-pillars without them? Can it cause any leaks or anything?
Many Thanks,
Hassan
i only put it back on so people have an oem look, personally i don't deem it neccessary but do it for the customer.
Ah...I had the impression it was an important component of the B-pillars. I would have not gone through the hassle of fitting them if I knew before :lol:
at most it makes the water bead from b pillar on to the glass and keeping it away from the glass seal (edge of the glass)
