ChrisS Posted October 7, 2010 Posted October 7, 2010 How easily are the handles removed? Guides or search will help viewtopic.php?f=35&t=23355&start=0&hilit=door+handle+removal Quote
Cal Posted October 7, 2010 Posted October 7, 2010 How easily are the handles removed? Guides or search will help viewtopic.php?f=35&t=23355&start=0&hilit=door+handle+removal Cheers for that! Regards, Noob Quote
ChrisS Posted October 7, 2010 Posted October 7, 2010 How easily are the handles removed? Guides or search will help viewtopic.php?f=35&t=23355&start=0&hilit=door+handle+removal Cheers for that! Regards, Noob Do youself a post in the into and welcome section,we will all say hi Quote
Ian Posted October 7, 2010 Posted October 7, 2010 u have to climb in the window or leave the boot open a bit you can't be serious... yup Quote
Tay Posted October 7, 2010 Posted October 7, 2010 u have to climb in the window or leave the boot open a bit you can't be serious... yup yup you're not serious? he's got handles on the inside so wouldn't it just be easier to open it from the inside? on a more serious note, are they hidden door handles as found on an alfa? Quote
TADDY Posted October 7, 2010 Posted October 7, 2010 usualy a remote button under the wing mirror Mine are painted Kuro same as the car best way looks like there suposed to be that way Quote
Ian Posted October 7, 2010 Posted October 7, 2010 u have to climb in the window or leave the boot open a bit you can't be serious... yup yup you're not serious? he's got handles on the inside so wouldn't it just be easier to open it from the inside? on a more serious note, are they hidden door handles as found on an alfa? But if you can only open it from the inside, how do you get in from outside without leaving a window open Serious answer: Door poppers, a button will fire a solenoid & pop the door open Quote
wide Posted October 8, 2010 Author Posted October 8, 2010 he's a big fan of the dukes of hazzard!!! lol are you for real??? Quote
