dr bru Posted August 27, 2006 Posted August 27, 2006 washer jets that clean the headlights have stopped working. Im assuming that this will be covered under warranty. Is it a big job to replace if need be? Quote
polarbear Posted August 27, 2006 Posted August 27, 2006 Nah, shouldn't be as they're only lifted by water pressure. Quote
dr bru Posted August 27, 2006 Author Posted August 27, 2006 could it be a simple matter that they have simply run out of water then?? Quote
lomoto Posted August 27, 2006 Posted August 27, 2006 a easy way to find out and check the oil as well Quote
Liam's Z Posted August 27, 2006 Posted August 27, 2006 Low water level is my guess as well top it up 2 max then try btw how are you testing them,,, just on the switch??? Quote
dr bru Posted August 28, 2006 Author Posted August 28, 2006 im assuming the place to refill is the name as the wiper fluid as these seem to be working fine ie hasnt run out of water Quote
Removed Posted August 28, 2006 Posted August 28, 2006 im assuming the place to refill is the name as the wiper fluid as these seem to be working fine ie hasnt run out of water correct also don't bother testing them with the button next to the VDC. I test them like this: switch the lights on then use the windscreen wipers. They should work simultaneously Quote
Liam's Z Posted August 28, 2006 Posted August 28, 2006 im assuming the place to refill is the name as the wiper fluid as these seem to be working fine ie hasnt run out of water correct also don't bother testing them with the button next to the VDC. I test them like this: switch the lights on then use the windscreen wipers. They should work simultaneously Val is correct they should work simultaneously but only on initial go, must be a timing sequence Quote
buds Posted August 28, 2006 Posted August 28, 2006 Waiting to hear back from OP to see if alls sorted now Quote
Liam's Z Posted August 29, 2006 Posted August 29, 2006 im assuming the place to refill is the name as the wiper fluid as these seem to be working fine ie hasnt run out of water BTW light washer reservoir runs out before window reservoir.... Reason being, what's the point of light if you can't see out the bloody windows Quote
dr bru Posted August 29, 2006 Author Posted August 29, 2006 havent had a chance to test it yet so is it just best to fill up the water reservoir then? Quote
lomoto Posted August 29, 2006 Posted August 29, 2006 havent had a chance to test it yet so is it just best to fill up the water reservoir then? Yes do it now and report back immediately we are all on tenter hooks Quote
Liam's Z Posted August 29, 2006 Posted August 29, 2006 looking for washer filler?? hope he get the rite one Quote
