Wing mirror guide
dangerman
:thumbs:
Mate there really easy to replace. If its the complete mirror just do the following...
Remove the padded arm rest behind the window controls etc by pulling it up...
Remove the rubber cap in the door control panel handle, then remove the Philips screw.
lift the hole control panel up after releaseing the clip on the end were you have removed the padded arm rest.
Remove the two big screws you will now be able to see, under the control panel.
Pull the inside door lever to the open postion and flip the plastic cap out where the little rubber circle is.
Remove the Philips screw.
You should be able to pull the door trim now and it will release from the door.
Unclip boh the cables attached to the inner handle.
Tada, door card off...
Undo the three 10mm nuts and the plug located below the mirror and remove the mirror.
This is the same for the passanger side, the only differece is you have to remove the Silver inserti in the door handle with a screw drive to find the two screw.
Hope this helps. :thumbs:
Alex
  • 2 months later...
