Brake calipers - to threadlock or not to threadloc
SteveW
Just a quick one really, I'm in the process of fitting my new discs and pads to the back of my car (turbogrooves and yellowstuffs) and I'm just wondering if I should threadlock the caliper bolts when I put it all back together?
there seemed to be some threadlock on them when I took them apart but can't be 100% could have just been other rubbish.
If I should threadlock them will Loctite 648 be ok? Strictly speaking its for gears on motor shafts etc but I have some lying around from other jobs?
Cheers
Steve
As Sunset said I would get the correct torque setting and maybe use temporary locktight. You can buy it online..It keeps the bolt solid but will be eaiser to remove if you ever have to...Goolge it dude... :teeth:
I'll have a quick look for the torque settings for you.
Alexz
